Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 11-18-2017, 9:25 PM
quarterwave's Avatar
Default Mobile Power Regulation
Since this is where everyone is posting about installs, I have a question.
Has anyone found a nice, small all in one UPS or capacitor type regulation system to combat voltage sag when cranking a vehicle? Some vehicles are good about it, and some are not, no matter where you pick up the power (at battery, dash, aux outlet). I can build one, but seems like there should be something out there...google is just not giving it to me yet!
It's an opinion. If you disagree, well, that's your opinion.
Old 11-18-2017, 9:27 PM
Mr_Boh's Avatar
Yes. PicoUPS. Hooked this up to a 1250 battery in the same mount used for batteries used for trailer brake systems (the kind that mounts on the tongue of the trailer). Under $100 for the setup with this, the box, and battery.
http://www.mini-box.com/picoUPS-100-...-backup-system
Old 11-18-2017, 9:37 PM
Mr_Boh's Avatar
Also don’t know what you’re trying to power but LIND makes “power conditioners” that have capacitors built in and can withstand engine cranking for like 10 seconds depending on device. They can be purchased as universal dc in dc out. They are just pricier. I don’t know if they still do but at one point they had vehicle UPS devices but they were definitely pricier than the PicoUPS.
Old 11-19-2017, 4:43 AM
abqscan's Avatar
DataBase Administrator
I too was looking for a vehicle UPS to combat the voltage drop during cranking. I did find a solution!
https://forums.radioreference.com/un...ed-solved.html
-Erik
I love my SBS-1eR & Mode-S Beast!
Rules and guidelines for forum post content
Old 11-19-2017, 6:57 AM
prcguy's Avatar
I bought one of these to calm down a 500W mobile HF amplifier: https://www.ebay.com/itm/UCAP16-58-U...gAAOSwu-BWOSO-
Before getting this capacitor I had to run a 100AH battery behind the seat of my truck right at the amp to deal with voltage sag on SSB voice peaks and to keep the amp from setting off all the dash warning lights. This capacitor is about 15 Farads at 17V and takes several minutes for a 20A power supply to charge it.
I also noticed my HF radio in my truck does not reset when I start the truck because the capacitor is 15ft of wire downstream from the battery and the capacitor holds the voltage at the radio very constant.
prcguy
Correction, the capacitor is 58.3 Farads!
Old 11-26-2017, 8:22 PM
northzone's Avatar
If it is just for a scanner:
https://www.amazon.com/DROK-Regulato...9BHN93JE7F7W8R
Old 11-26-2017, 8:43 PM
KK4JUG's Avatar
I have an AGM battery in my '16 Sorento and it maintains enough voltage to keep my Yaesu FT-8900R powered up during car starts. As the battery ages, it may not stay that way. Mine came with the battery but I think they're a little pricey to replace: $325+ at the dealer.
Old 11-27-2017, 6:59 AM
I picked up a device for a few bucks that delays the radio turning on for whatever time I select. I set it for 8 seconds, because I never have to crank the engine for that long. So when I get in the car, & turn the key, the radio gets no power for 8 seconds, so it is never on while the engine is cranking. This particular device is used in elevators to control how long the doors stay open when the elevator stops on a floor. Not much bigger than your thumb.
FORMERLY MOONBOOTS
Old 11-27-2017, 7:15 AM
n9mxq's Avatar
Not really a conditioner, but I use one of these. Keeps the power off if below a certain programmable voltage.
Http://www.byonics.com/apo3
Sent from my SM-G950U using Tapatalk
Gene
Transceivers, receivers, and SDR! Oh My!
