Magnet mount antenna - secure cable?
SonicN
I’m planning on mounting a HF antenna on a magnet mount on my van, but are looking for solutions for securing the cable, so that is not jumping around on my roof damaging the paint. Does anyone got a tip on how to make the cable secure so it stays still ?
Two of my other antennas is mounted on a cargo rack, but it can’t be three antennas on it..
Well, more magnets would do it, but that still risks damaging the paint. There are small nylon cable tie mounts that are designed to be stuck on with the included double sided tape. Getting a few of those and some suitably sized magnets might work.
Curious how big your mag mount is for an HF antenna? Seems like if you were concerned about the coax damaging the paint, you'd not want to be using a big antenna with a big mag mount.
teufler
ST PETERS, MISSOURI
most hf mag mts that I have used, use 3 or 4 magnets. Because the antenna is so long, roof mount is not very practical. Mounting on a trunk lid, though you have mentioned you have a luggage rack. Can you mount the antenna between the luggage rack side pieces, Then use tie wraps to attach the cable to the rack, so you should only have maybe 4 inches that would flap in the breeze. Then run the cable though at a door. Best I did was a mount on a trailer hitch. Because of the height of the antenna, any higher, it struck trees.
N3LER
Surprise AZ
Canadian Firm
I bought a couple of magnetic clam type mount to affix my cable. They were originally designed to hold the ac cable for electric crankcase heaters from banging around the front of the car. It was a canadian company. I will check the items themselves to see if there is any mfr data and post later.
