Hi all
Looking to power a Kenwood VHF mobile and a Uniden 996T scanner in a 2016 GMC Sierra. Normally I would just use fuse taps and be away but much to my surprise; the truck has 3 blade fuses which is new to me. Micro3 fuses. I can’t find taps anywhere other than amazon with 3 blades.
There is an accessory blade on the drivers side fuse panel but only 1 but it is beside a 50 relay
My question is....
Can I crimp both positive wires together into 1 female spade connectors and have both units powered from that 1 blade beside a 50 amp relay? See attached pic. Not my pic but same set up except I don’t currently have anything on my blade.
Confirmed this blade is RAP power aswell so it would be perfect if I can run both positives from it.
My question is....
