Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 12-29-2017, 8:18 AM
Danny37's Avatar
Default 1 power supply for 2 radios, how to?
So I have two vertex vx-4207 mobile radios that I use as scanners. One has been collecting dust in storage for a while so I thought I should I hook it up. There's no transmitting on these radios as they are used specifically for receiving purposes only. I have a 10 amp supply for one of them and I'm clueless on how I should hook up the second one. Is it safe? Do I need to buy fuses for the 2nd radio? (The one I use currently has fuses) is there a spiltter of some sort to split the power? links for products (preferably on Amazon) would be really appreciate.
Thanks in advance
Volunteer EMT
Old 12-29-2017, 8:37 AM
davidzimmerman's Avatar
i use a Astron 10 AMP on all 3 Motorola radios for base use only TX on 1 radio all 3 have the Motorola Power Cables i just hooked all 3 to the Power Terminal on the rear of the Power Supply.
Old 12-29-2017, 8:42 AM
There shouldn't be a problem. Hook them up in parallel. Connect the plus lead from each radio to the plus terminal on the supply and the negative lead from each radio to the negative terminal on the supply.
You won't need to by fuses for the second radio, but it's good practice to have fuses.
Old 12-29-2017, 8:48 AM
Danny37's Avatar
So bare wire from both radios making contact with each other won't do any damage to radios or the power supply when I connect them to the leads?
Volunteer EMT
Old 12-29-2017, 9:19 AM
FedFyrGuy's Avatar
Or you could get really fancy with one of these:
https://powerwerx.com/powerpole-power-distribution
West Mountain Radio - RIGrunner Models
MFJ Enterprises Inc.
But you've gotten some good advice from others also. Good luck!
N3PAG
Relm MX4000, RS Pro-18, Pro-136, Pro-668, Pro-2028, Pro2066, Pro2096, Pro2052, Pro2055, BC HP-1, HP-2, 345CRS and a Lafayette HA-52A just for old time's sake.
Old 12-29-2017, 10:00 AM
KevinC's Avatar
Moderator
Posts deleted. If you don't plan on helping then please don't reply. Thank you!
Someone told me signatures are silly, so I got rid of mine.
Old 12-29-2017, 10:14 AM
"...bare wire from both radios...", Danny, are you talking about bare copper wire? The insulation removed?
Dangerous to you, the radios, and the power supply!!!
FT-2900R, FT-101EE, HTX-202, IIC-2AT, BTX-121, UV-5R, KT-7900D
Old 12-29-2017, 10:37 AM
W9BU's Avatar
Lead Wiki Manager
Thread moved. The OP isn't using amateur radio equipment and his question has more to do with radio installation than it does amateur radio.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 12-29-2017, 12:06 PM
mmckenna's Avatar
Yes, it's safe as long as you properly fuse the radios.
Strongly recommended, however there are multiple ways to do this, see below:
Sure, Something like this would work:
https://www.amazon.com/Seachoice-ATO...rds=fuse+block
It allows you to fuse each radio individually as well as provides a connection point for the negative leads. I've used similar fuse blocks on installs, and they work well.
Old 12-29-2017, 3:25 PM
k6cpo's Avatar
This fuse block doesn't make accommodation for the negative return lead. That would have to be a separate piece.
Something like one of the fused RigRunners mentioned above would be a better approach. Here's the setup I use in my shack:
The lead on the left to the 40A fuse comes from the power supply. The other three leads, each fused at 25A got to a 2m/70cm mobile, a 6m mobile and an iCom HF radio. The only issue with using something like this is that it requires the ability to install Anderson Powerpoles on all the leads.
Old 12-29-2017, 5:16 PM
mmckenna's Avatar
Look closely at the bottom right in the photo. That's the negative buss.
Old 01-02-2018, 6:19 PM
737mech's Avatar
Default power supply
I currently run two switcher power supplies to power my scanners. One is sec1212 powers two bct-15X's, a psr-410 and a pro-2042. The second powers three scanners bct-15/ pro-2051 and bcd-536hp that power supply is repurposed from an old motorola repeater. I installed volt meters on both and have had zero problems for a few years now. You can see the volt meters 13.9 and 13.7. I really like those rigrunner modules! Looking into them now!!
Old 01-03-2018, 11:46 AM
Danny37's Avatar
737 that setup is so clean man.
Volunteer EMT
Old 03-07-2018, 6:51 PM
scanmanmi's Avatar
Mine hasn't caught fire yet.
Second place is the first loser.
Old 03-07-2018, 8:49 PM
Been following this thread; I've found this for multiple radio powering:
Cooper Bussman #15600 series;
http://www1.cooperbussmann.com/pdf/c...bef755608b.pdf
4 thru 20 circuits, option for a common ground terminal, standard bl
ade fuse holders.
