scottbailey
We're about to contract for a semi-custom house build from the ground up - any recommendations on what to spec out related to radio? It will be a two-story home in a HOA community, so may be limited to attic space for antennas. I'm in the north Dallas area, so lightning strikes are definitely a risk.
My interests are VHF/UHF/800 and may host a neighborhood-level GMRS repeater (since I have a spare) and will have Motorola gear and a scanner or two in two locations in the house. No low band/HF interest (and don't expect that to change).
So far, I'm planning in-wall 2" conduit from both locations to the attic, requesting to minimize turns and angles, terminated into a double box with blank faceplate. I'll also get a dedicated 20amp circuit to cover a low-level repeater. I know I'll want to make sure there is ground available in the attic, but I'm wondering if I should try to get them to put in dedicated ground for radios separate from electrical/pipes.
Thoughts?
Thoughts?
