Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
  #21 (permalink)
Old 04-21-2018, 11:26 PM
mmckenna's Avatar
Originally Posted by Token View Post
Note that not all F250s have this ability, but I think most do, and I think all F350s do. At least, I have seen an F250 that you could not do this with, and I have not seen an F350 that you could not so configure.
The F-250, F-350 and F-450 are the same. I've got the F-350 and the 2 switches can be changed by moving the fuse you mentioned.
I've wired one to activate the Battery Charge Protect system. I'll probably use another for rear floods once I put the headache rack on. The others will probably never get used.
  #22 (permalink)
Old 04-23-2018, 7:09 PM
N9JIG's Avatar
Sheriff
I saw your post about your F350's but the pictures are too small to make out anything. Does yours have the center console?
Rich Carlson, N9JIG
Facts are facts but my opinions are my own and may not reflect those of whom I work for.
  #23 (permalink)
Old 04-23-2018, 8:18 PM
mmckenna's Avatar
I reposted with bigger photos, but it looks like the moderators misunderstood my request or chose to keep the smaller ones.
Anyway, it's got the 40/20/40 seat, so no dedicated center console. Just the middle seat that folds down. It's an XL trim, vinyl seats and rubber floor. Helps with the kid and dog clean up. A lot.
If you need specifics, let me know and I can get that for you.
  #24 (permalink)
Old 04-23-2018, 8:50 PM
W9BU's Avatar
Lead Wiki Manager
On an F-350 XL SCrew, it looks like the front seat choices are limited to a 40/20/40 split bench in either vinyl or cloth. But, I think Rich is thinking about a nicer truck than an XL and that's where things get more complicated. Move up to an XLT and the choices are 40/20/40 split bench or 40/console/40, both in cloth. Move up to a Lariat and the choices are 40/20/40 split bench or 40/console/40 both in either cloth or leather.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
  #25 (permalink)
Old 04-23-2018, 10:02 PM
mmckenna's Avatar
I've never tried it, but it looks like the center "20%" seat would be easily removable. Probably not hard to fit a Havis, etc. console in there.
  #26 (permalink)
Old 04-23-2018, 10:13 PM
Ravenkeeper's Avatar
Originally Posted by Mr_Boh View Post
Sound like a Ford guy, but I think this is the most attractive option right now for a “civilian” model pickup that retains the center console features:
Sierra Console Plate
All the other civilian model console kits seem to be for SUVs. The Ford standard console could fit two scanners in the center console if you wanted to test some fabrication skills but I haven’t seen off the shelf products for that yet.
Glad I stumbled across this one. I've been trying to plan something like this for my Silverado.
  #27 (permalink)
Old 04-24-2018, 6:38 AM
W9BU's Avatar
Lead Wiki Manager
Pretty much what I did in my 2011 F-150. I had the 40/console/40 seat, so I removed the console, installed a floor plate from either Jotto or Havis, then attached a Jotto console to the floor plate. The outer seats are the same whether you get the 40/20/40 seat or the 40/console/40 seat--only the center section changes. And, it all just bolts in.
