Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 04-04-2018, 1:22 PM
Default Underside clearance on NMO mount
I was planning on mounting an antenna or two on my trunk and was wondering how much space the interior parts take up. Due to the reinforcement parts of the lid, I only have 2 1 inch by 7 inch channels that giveme access to the outer metal part of the trunk lid. Iím attaching a photo for reference.
Old 04-04-2018, 1:35 PM
jhooten's Avatar
You will be fine in either. Even with the plastic protector in place the mount only intrudes about half an inch.
Jerry
I read it on the internet, so it must be true.
Old 04-04-2018, 1:42 PM
I’m worried about the minimal width required to install. Depth isn’t an issue.
Old 04-04-2018, 2:48 PM
Originally Posted by JeffDS3 View Post
Iím worried about the minimal width required to install. Depth isnít an issue.
I donít have the exact measurement but the ďclawĒ that goes under the metal is not an inch wide. I think itís closer to 1/2Ē.
Youíll be fine.
Sent from my iPhone using Tapatalk Pro
Old 04-04-2018, 6:23 PM
jhooten's Avatar
Now that I'm home the spare Motorola branded one hanging over the rafter in the garage is 7/16X15/16".
Jerry
Old 04-04-2018, 6:34 PM
Plenty of room. Just orient the mount so it runs horizontal with those cut outs. I don't see any issues here with using regular NMO mounts.
Old 04-04-2018, 7:11 PM
Thanks. I didn’t think there would be a problem but I didn’t want to order up everything and then find out it won’t fit.
