Roof Mounted Mobilr Antenna
oopie41091
KY
I purchased an old chiefs SUV from a fire department. When I installed my mobile in the vehicle I had a magnetic mount antenna. Well I'm am upgrading my radio and antenna. I have a one inch hole in my roof from when the fd had it. I did drop the headliner and found the old coax cable with a nmo mount its 3/4" . How did they pull that off? I want to use that existing hole. What options do I have? Thanks.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Are you sure it's a 1" hole?
If so you will have to run something like a Breedlove mount. If it's 7/8" (because occasionally upfitters fail to acquire the proper tool for the job) you can typically get it close enough to work.
You'd probably need to get creative with some sheet aluminum or stainless steel and make a big enough washer to plate to go over the hole. Seal it well, put a 3/4" hole in the center.
Or better yet, plug the 1" hole and make the correct sized hole.
oopie41091
KY
I guess I will plug it and make a new hole. Any recommendations for an antenna for a kenwood tk-7180. The cable that is already ran is smaller than the pl-259. So it wont work with the 7180.
Project25_MASTR
Texas
Probably a Mini-U, common to Motorola. Doesn’t really matter though if you are going with a new kit. Get a 1/4 VHF antenna centered to 146 MHz if you are specifically interested in 2m. You could run a 5/8 wave antenna as well but the bandwidth will be narrower.
Yeah, ditto on the 1/4 wave antenna. Wide bandwidth can be handy. They are lower profile, cheaper, and if you decide you need something else later on, you are not out a bunch of money.
oopie41091
KY
I am in a rural setting with high hills and low valleys all around. I need maximum range.
oopie41091
KY
Also my bandwidth is 151 to 156. I don't need much more for what I need it for and all of my frequencies are narrow band.
Roughly how long of an antenna do you suggest?
1/4 wavelength on your frequencies (151 to 156MHz) will be about 18 inches long.
You can purchase "pre-tuned" antennas that are usually right on.
https://www.theantennafarm.com/catalog/larsen-nmoqw152-723
This antenna is 152 to 162MHz.
They are broad banded enough that they will work fine outside that range. I'm running similar antennas on my personal and work vehicles. Putting these on an antenna analyzer shows a less than 1.5:1 SWR from 144MHz to up near 174MHz.
