Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 07-30-2018, 6:41 AM
Default Antenna Splitter Help Needed
Hello,
As I cannot seem to find one on the market, I am looking to build a splitter that will go from 1 x N-type to 2 x F-type connectors. I come from an audio and electrical background, and have little knowledge of radio signals. Does anyone have any circuits that would achieve this with a minimal signal loss?
The application is for a ship's entertainment system, so AM/FM radio mainly.
Old 07-30-2018, 6:22 PM
Receive only or transmit and receive?
what power level if transmit?
jay thompson / CETsr, GROL
COML, COMT trainee
KC9VTT / COML DMAT CA-4
you must be really bored to be reading this far down
Old 07-31-2018, 3:40 PM
prcguy's Avatar
Is your antenna a single passive AM/FM combo or an amplified model or what?
Using a passive splutter will cut the signal level to each receiver by at least 50%, so if that's ok here is one that will work for your needs. https://myradiostore.com/mb-2-multi-...fhd-4-antenna/
I assume you have one cable from the antenna that terminates in an N male connector and if so this adapter will screw onto the splitter and accept and N male: https://www.ebay.com/itm/1Pc-Adapter...LH_TitleDesc=0
Originally Posted by allongsound View Post
Hello,
