Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-03-2018, 10:15 AM
Default Running wire and coax in a Ford 2017 F150
What is the best way to run wires and coax ? Wires will be directly from the battery. Is there a place on the fire wall or under the driver side mat?
Bobby
Old 08-03-2018, 10:56 AM
K7MFC's Avatar
Not sure about the current gen F510, but on the 12th gen F150s there is a big grommet on the driver's side of the firewall with a nipple that can be cut off and power/coax fed thru there:
Matt Callahan | K7MFC | WRAA720
K7MFC.com | Arizona GMRS Repeater Club
var radioList = new List<Radio>();
Old 08-03-2018, 11:09 AM
Many Thanks......................
Old 08-03-2018, 4:26 PM
Don't run Negative directly to the battery
Old 08-03-2018, 5:01 PM
K7MFC's Avatar
Good point - pretty sure this is also true for many other newer vehicles as well.
Old 08-04-2018, 7:44 AM
Thank you for that information. Now if I can just get thru the firewall...........................
Old 08-04-2018, 9:37 AM
K7MFC's Avatar
Post back with pics when it's done! Of all the trucks I've owned, my F150 is one of the easier vehicles to install accessories in. You shouldn't have any trouble getting the power and coax up into the cabin.
Old 08-16-2018, 5:54 PM
If you have the super cab there is a grommet in the floor under the rear passenger seat. In my case it was under the AC inverter.
