Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-21-2018, 2:48 AM
scannerowner's Avatar
Default Scanner/Radio Install in Home
How can I ground the antennas that I would put on the below?
https://www.cheapham.com/tram-1465-n...und-plane-kit/
Trying to think of the best way to ground equipment, and using these mounts with old antennas.
CERT Member
Scanners: Uniden BCD996T & Uniden BCD396XT
Radios: Baofeng UV5R, Yaesu FT2DR, Anytone 5888UV
Old 08-21-2018, 4:42 AM
krokus's Avatar
Run a ground lead, using the most direct route, with no sharp bends, to a ground rod. That ground needs to be tied into the ground for your structure.
Sent using Tapatalk
Old 08-21-2018, 4:22 PM
I watched a YouTube video of a guy that had this mount and he didn't ground it.
CERT Member
Old 08-22-2018, 3:34 AM
krokus's Avatar
Since there is no grounding point, it is not made to be grounded. It is your choice.
Sent using Tapatalk
Old 08-22-2018, 11:02 AM
mmckenna's Avatar
Any antenna you install outside your home needs to be grounded per the National Electric Code. Doesn't matter if it has a grounding point or not.
There's a lot of stupid stuff on YouTube, so not surprising that there's someone telling you to install an antenna outside your home and not ground it.
Ultimately it's your choice to ground or not ground the antenna. The National Electric Code exists for a reason, and it's not there just to make hobbyists life harder.
Old 08-22-2018, 11:07 AM
mmckenna's Avatar
Ideally, you'd run a 6 gauge or larger copper conductor from the antenna mount straight down to at least one ground rod directly below the antenna. Per NEC, you need to bond that ground rod to the ground rod for your home.
You also want to ground the coax outer shield and install a lightning protection device like a PolyPhaser before the coax enters the home. Grounding the support mast would be a good idea, too.
The number of ground rods you need depends on soil conductivity. One 8 foot rod would be a good place to start, more might be needed, but that's getting outside the hobby realm.
Old 08-22-2018, 11:18 AM
You would need a coaxial ground connector. It sits between your coax cable and the antenna connection. The place that sells the antenna would be the best bet to have them.
Bud
Pro-34/Pro-97/PSR-500/BCD436HP/TRX-1/SDS100
Old 08-23-2018, 11:46 PM
Can you run shielded coax on the shingles?
CERT Member
Old 08-23-2018, 11:59 PM
mmckenna's Avatar
Yes.
Old 08-24-2018, 12:08 AM
cmdrwill's Avatar
Being that the antenna does NOT have a grounded element, you need a coaxial lightning arrestor at your ground rod.
Old 08-24-2018, 7:48 AM
What about shielded copper wire over shingles?
CERT Member
Old 08-24-2018, 8:57 AM
krokus's Avatar
Never heard of shielded wire, only shielded cables. (Like Cat 6 network cables, or coax.)
Sent using Tapatalk
Old 08-27-2018, 9:53 PM
What about doing a magmount antenna outside? I won't keep very high up, but how to know what size ground plane? I also have an old NMO trunk lip mount that can use. Height shouldn't be an issue, since the local repeaters are 10-15 miles away.
CERT Member
Old 08-28-2018, 12:04 AM
mmckenna's Avatar
You'd still want proper grounding, but that's up to you.
A mag mount or trunk lip mount will work. You need 1/4 wavelength around the mounting point at your lowest operating frequency.
At VHF, you'd need 18 inches, or, 36 inches across. If you are only running UHF, then you need 6 inches, or 12 inches across.
Old 08-28-2018, 6:26 AM
A magmount on top of a tall metal filing cabinet or on a cookie sheet up as high as you can get it by your operating position may be sufficient if the repeaters you're interested in are only 10-15 miles away and they're at a decent height themselves.
Give it a try.
John
Peoria, AZ
Old 09-01-2018, 6:56 PM
What would happen if I mounted the antenna on my screen window? It's 24" by 24"
CERT Member
Old 09-01-2018, 8:01 PM
mmckenna's Avatar
Depends on a lot of factors.
If you want the antenna to be vertical, which is really needs to be, then the ground plane is going to be running in a less than ideal direction. You want the ground plane under the antenna, like it would be mounted on a car.
If you mount the antenna on the top edge of the window frame, you might have issues with the building materials behind the wall. Often the insulation will have a foil backed vapor barrier that will block reception. Stucco homes will have a metal lath behind it that can create the same issues.
You can certainly mount it however you want, but outside, up high and with a good ground plane are important factors. Take any of those away and performance will suffer.
Old 09-01-2018, 11:47 PM
jeatock's Avatar
Default Read 'The Bible"
Nothing is too small for grounding, until you have a problem.
Mother's R-56 antenna manual answers the simple question. There are only two hundred or so detailed technical pages on the subject.
In summary:
1. Bond -everything- together with the biggest wire possible, avoiding bends. Lightning is lazy and will only turn if it has no other choice. The ground wire is a suggestion for lightning, not a rule. Lightning already traveled thousands of feet through the air, so jumping another five feet to the air conditioner is easier than following a sharply bent wire.
2. Bond at least one 8' ground rod to the antenna system via #6 (#4 is better) and to your building electrical ground. More ground rods ten feet apart are better. Bare wire buried is also a grounding surface.
3. If possible, ground all coax at the top, every 50' coming down the tower, and always before making the turn into a building.
4. Install lightning arrestors on all coax and bond them to your grounding system.
5. If in doubt, re-read items 1 through 4.
If you think you have a failed ground, call your local rock quarry and find out who does their annual MSHA testing. That electrician has the special tools to check your grounds. Most radio guys don't.
Personally, I have three ten foot ground rods buried in my yard in a fifteen foot triangle connected by bare #2 copper and exothermic welds. One #4 connects to my radio equipment ground bar, one #4 to my 30' tower next to the house, and another #4 to my electrical entrance. Most of the copper was bought by the pound from a recycler, The insulation had been removed, and that was perfect for my needs. It wasn't bright and shiny, but after a week in the ground would't be anyway.
Overkill, but a couple years ago, my utility power drop neutral failed on the pole end. The voltage imbalance would normally be fatal to refrigerators and TV's, but because of my 'overkill' bonded grounding system the only way I knew of the failure was the sagging power line. The amperage flowing into the ground would have melted a #10 wire connecting my radio ground system to the house utility ground. That's why the NFPA code is so strict.
Another grounding story: a new government client said they were having lightning problems at their office. Before I could go out on an inspection another lightning strike traveled down the tower, jumped to the electrical system, blew up the Sheriff's microwave, and jumped between four metal filing cabinets before finding the main (copper) water line. I will summarize the secretary's description as impressive, thereafter necessitating a trip to the ladies room.
The 199' tower was ten years old, and the installer (long out of business) had grounded it with a single #6 wire on one leg. Tugging on the wire confirmed my suspicions: it was two feet long and went nowhere. Since the whole area had been recently paved in concrete, the only solution was drilling a 40' copper pipe into the ground and bonding/grounding everything to R-56 specs. A qualified electrician corrected the local building maintenance staff's 'repairs'. That was seven years ago and the tower still gets hit once a year. The Sheriff reports that his seven year old microwave is still working.
Public Safety Communications Consultant and Technician, Firefighter / COML, Interoperability Crusader and Slayer of Dragons (aka Proprietary Systems)
