Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Radio Equipment Installation Forum
Radio Equipment Installation Forum - Forum for discussing how to install radio communications equipment in Mobile, Base, Command Post, EOC, etc configurations.
Old 08-24-2018, 8:41 PM
Question Double DIN radio bracket
I have a 2002 Mazda B2500.
It's basically the same as a Ford Ranger.
The Stock factory radio died.
It was Double DIN size.
I wish to replace the stock radio with a new Single DIN radio in the top slot of the bracket, and place a
TYT 7800 control head on a blank face on the bottom of the Double DIN Bracket.
I cannot find a Double DIN Bracket with on Single DIN hole on top and a blank face below.
All I can find are Double DIN brackets with a single DIN hole on top, and pockets below.
Can anyone point me to a website selling Double DIN brackets with a single DIN hole and a blank face below?
Dan
AI8O
Out here on the cyber equivalent of a dirt road, Way off the Information Superhighway!
Old 08-24-2018, 8:51 PM
SteveC0625's Avatar
Default Double DIN radio bracket
Dan
AI8O
Check crutchfield.com
I've also had good results on EBay. Just shop the seller as much as the item. I stick with US buyers with plenty of sales and 100% (or close to it) feedback. The double din adapter in my F250 was found on EBay. It was very easy to make up a strong blank panel to mount a Garmin GPS and a XM tuner.
Rochester-Monroe County 911 7010 1976 to 2003
Northampton Ambulance - Car 2829
KD2IAT --- WQPG808
Old 08-25-2018, 5:15 AM
K4EET's Avatar
Smile
For your Double DIN housing for a Single DIN radio head installation, can you use a Single DIN blank faceplate like this:
https://www.bimmerworld.com/BMW-Inte...1-384-855.html
Make sure you verify something like the above will work with the Double DIN housing.
73, Dave K4EET
Retired E911 Police Communications Systems Manager
BC800XLT (1978) and BCD536HP (2015)
NOTE: Also a Motorola Police HT "Scanner" while working...
Old 08-25-2018, 6:41 PM
TU K4EET!
That will do the job.
So what I will do is install a Double DIN bracket with two open slots, mount my entertainmanet radio in the top slot, put this blank faceplate in the bottom slot, and mount my control head to the blank faceplate..
I knew this had to be found somewhere, I just couldn't find one.
Again TU
73
Dan
AI8O
Old 08-25-2018, 7:31 PM
Dan
AI8O
My 2002 F150 shipped with a 1.5 DIN radio (which was standard at the time) while Chevy was shipping their trucks and SUVs with double DIN radios. May want to double check on that.
Old 08-25-2018, 8:38 PM
My 1998 Toyota Camry has a double DIN with a pocket in the lower half. The control head for my TYT TH-7800 fits very snugly in the pocket. I only had to drill a small hole in the right lower corner of the pocket large enough for the extension cable to fit through.
The control head for CS800 fits nicely in the 'change pocket' just under the cig lighter and ashtray.
Bill
N4GIX - Ham / WQWU626 - GMRS
TK-840(N), TK-880-1, 2xTYT-7800, 2xUV5R v2+, HP1, BCD436HP, TMV7A, 2xRitron RRX-450 Repeater, MD-380, XPR7550, 2xCS800, BCR-40U Repeater, IC-7300, G5RV-JR
Tags
din, double din
