You won't need a lot of battery if that's all you plan on running remotely. Figure the drain (amps per hour) and you likely will be able to get by on a small deep cycle battery. I have a larger one, a Group 29 marine/golf cart deep cycle, in a converted Coleman cooler sitting under the operating table for UPS/ power outages and remote use. In the cooler along with the battery is a trickle charger with de-scale capability (BatteryMinder.com) and a small (120 watt) inverter, should I want to power something off 120 volts for a time. The cooler is vented with little round house vents available from Home Depot/hardware stores, and has a 12 volt socket on a bracket for auxilliary 12 volt uses. Fuse block/terminal block is screwed to the inside of the lid. Total cost under $100 with battery. Been in use more than 4 years with no ore maintenance than checking the battery fluid once a month or so. If you have the space, that's a good solution that will lend itself to other uses too.
