Zetron encoder
kyparamedic
Central KY
I'm not sure if this goes here but it looks like the most appropriate forum. Does anyone know of a table that lists the tone frequencies for the Zetron Model 5? I believe it is the Model 5. It looks like it but maybe an older version. Maybe each encoder has different setups. I just know that where I used to work 01 would be the lowest set of tones and the higher up you went, up to 99, the higher the frequencies.
Thanks.
firemedic2150
Senior Member
Right here...
If I am not mistaken the model 5 is programmable, so what tones correspond to what you enter was not a set in stone thing.
MMc.
kyparamedic
Central KY
Ok. This is an older one, it does not look exactly like the one on the website but it probably just an earlier version. I doubt they customized it as it's not actually used to set off pagers but I kinda figured each one might be setup differently. Are there default settings for them?
Thanks.
