Is it possible to remote mount the LCD Only?
safetyobc
South Arkansas
Just curious how hard it would be to take an old Pro-93, 95, or similar model and mount somewhere in my truck with the LCD only installed in the dash?
Removing the LCD, running cable(s) that would extend the original so that the LCD could be mounted in the dash and the scanner under the dash or under a seat?
How big of a project is this and is it even realistically possible?
k0pwo
Centennial Colorado
Its possible to do what you are asking and it has been done by others in the past. However, the degree of difficulty is dependent on each model. On most of the current model lines, it will require the extension of lots of wires.
safetyobc
South Arkansas
How about modding a Pro-93 or Pro-95 to do this? Or possibly a BC780XLT? Too Difficult?
bctrl1
The LCD controller in the 780 only requires 7 connections, but there are still 15+ connections for the keypad/backlight, power, volume, squelch, etc. Its generally not a good idea to extend these lines. It may work, but the circuits were not designed to drive long cables. If not extended properly you introduce potential entry points for RF interference, and run the possibilty of generating interference from clock and data lines. There are a host of problems that could arise.
For the 780 the remote head at the following link might possibly be an easier solution.
http://www.scancapecod.us/wiki/index.php/Bearcontrol:_Uniden_Scanner_Displays
It can be configured with or without a keypad, and the scanner still remains unmolested.
