N8IAA............. i have all the freqs store into bank one. just trying to scan them. it continues to scan and never finds the dang control channel. i have the manuel and im doing everything by the book. not sure what my deal is
You need to make sure it is in Trunking mode and not conventional.
Hold down Trunk until the scanner beeps twice
(BANK, TRUNK and the bank numbers flash)
- then select the bank the trunked system is in that you want to scan
- then press Search (which will search in open mode, no need for talkgroups)
If you manually step through the frequencies, do you _hear_ the control channel?
NOTE: If you press SCAN instead of SEARCH, then instead of running in open mode it runs in closed mode (scans only the TGIDs you have entered into the scanlists). If you have not entered any TGIDs into the scanlist and you are using SCAN, you won't hear anything.
The manual says:
Your scanner's squelch setting is automatically adjusted in the trunking mode, which means it is not necessary to manually adjust squelch while tracking trunked transmissions. However, the squelch setting can affect how fast your scanner acquires the data channel, and, in some instances, can prevent your scanner from acquiring the data channel at all.
The manual then goes on to recommend that the squelch be set so that the dot on the knob is facing the word 'squelch'. What they are saying is that even though they claim the squelch setting doesn't matter, it does - and you shouldn't run with the squelch in a position where you hear static on a frequency that has no transmission.
