Old 01-31-2009, 5:53 PM
Question PRO 164 programming
Greetings
I purchased a Radio Shack PRO 164 scanner today and would love to be able to program all of my local frequencies (Trunk IDS also) into my new scanner. I became a subscriber here in hopes that someone that is knowledgeable with this scanner could set me on the right path. I have the cable that can attach to my laptop and connect my scanner to the PC. What software do I need and where can I find the correct frequencies. Please help me make this as painless as possible if you can.
Thanks in advance.
Old 02-01-2009, 4:31 PM
scannerface27's Avatar
Cool helping
dear cheifpropellrerhead.... i have a 164 also ive had it know for about a month. all you need to do is search the rr database for scarolina, find what you want and program it in your bank..or if you want good and easy to follow arc-300 software is very good.. i am old school and do mine by hand, but i did also use this software for the first time and like it alot...happy programing...
2-pro-92's-bcd396xt-pro-163-bc200xlt..pro-95,
c.j.u.h.s.d. school officer."10-6 ALL DAY"
scannerface 27-
Old 02-01-2009, 11:34 PM
Default Where can I download the frequency db for Berkeley County
Thanks for your response.
I have Scancat installed on my laptop. I am a premium member here. How do I download the frequencies list for Berkeley County for my Pro 164. I need a simple how to guide please.
Old 02-02-2009, 12:46 AM
Default hope this helps
try South Carolina Scanner Frequencies and Radio Frequency Reference if youre useing win 97 its very easy to set up.
Old 02-02-2009, 8:20 AM
Question How can I download the db files for win97 to use?
Ok, I will download win97 and see if that will work. I still do not see HOW to download the frequency database for berkeley county here in SC. All the website page says is that you need to be a premium member of this site which I already am. Are there no simple instructions for how to do this?
Old 02-02-2009, 10:25 AM
N8IAA's Avatar
When you have Win97 downloaded and running, [make sure that you are connected to the internet ], click on File, click on web import. Pick trunked, or, conventional. It will take you to the Web Import on radio reference. Follow the directions, and pick your system, or set of conventional frequencies. Check all the boxes that apply to what you want to monitor. Follow the prompts to add it to Win97. I use it to make up files for my 106 and 163.
Larry
Old 02-02-2009, 5:30 PM
Wink Thanks
Ok, I was able to use Win97 and RR database to upload my first batch of Trunked frequencies to my Pro 164. Thanks. I just need to read the manual and figure out how to go from Trunked scanning to conventional scanning. For now I use my old Bearcat Scanner for listenting to the local PD. Sort of silly since I have this new whizbang toy of mine. LOL. Thanks again Larry
Old 02-03-2009, 12:10 PM
N8IAA's Avatar
Have you put the conventional in banks other than the trunking banks? If you have, you just need to activate the different banks by pressing on the corresponding number on the keypad. Then just let the scanner do its thing
Larry
Old 02-03-2009, 5:14 PM
Talking changing banks
Larry
Ok, dont laugh. I spent several hours last night playing around with this PRO 164. I have bank 0 for Trunk tracking and then I uploaded conventional frequencies to bank 1. When I turned the scanner on it went straight to Bank 1 and started to scan there. However I was unable to figure out how to switch from bank 1 to bank 0. The manual says to just use the number pad to switch but for the life of me I could not figure out how to tell the scanner I want to change banks and not channels. I know you have to take it out of scan mode by hitting Man button. I got things so hosed up at one point I had to reinitialize the scanner and then reload bank 0 with the trunk information. Now I need to add the conventional channels again and figure out HOW to switch banks. One step at a time...
Old 02-03-2009, 5:15 PM
Thumbs up Thanks
Thanks for the input...
Old 02-03-2009, 5:16 PM
Talking Thanks
Larry
Ok, I am slowly but surely learning how to use the app. I have it working now and I know how to downlaod the frequencies or trunks that I want and send them to the scanner.
Thanks again
Old 02-03-2009, 8:36 PM
N8IAA's Avatar
Manual has nothing to do with changing banks. You change banks by pressing the # on the keypad while the scanner is in the SCAN mode. If you want to listen to Bank 1, press the #1, then press the #0. That takes you out of the trunking bank to the conventional bank. I chuckled because it took me a while to figure out how to do all that when learning how new scanners worked. It took me almost a month to catch on to my 106. It was waaay different than my 96 and other bank challenged scanners)
Larry
Old 02-03-2009, 8:48 PM
Talking Pro 164 has no such key
Larry
Ok, I looked at the keypad on my Pro 164 and it does not have a # key. What now? LOL... Thanks for helping me.
cheers
Old 02-03-2009, 9:26 PM
N8IAA's Avatar
cheers
Now I'm laughing<Grin> #= #1 key, #2 key, etc., etc., etc.. Not like the pound sign on a phone)
Larry
Old 03-10-2009, 6:30 PM
Default Has any one had any luck with the new 700mHZ
Has anyone had any luck setting up the 700 mhz interoperatible channels?
Old 03-15-2012, 12:30 PM
MistressGwen's Avatar
can u PLEASE list the procedure for manual programming - I dl'd the manual for this and it tells u how and I do it- but then it says the frequency I want to program in is invalid... I have a uniden bc200xlt -older model - but its only 100 channel - its so easy to program anything in- doesnt reject a thing - great scanner - my battery is bad - so its always plugged in- why cant this thing be that easy! thanx for your time...
Old 03-25-2012, 5:08 PM
Talking scanner programming
Have the RS 164 scanner - figured it out myself- works like a dream! if u love scanners - this is a nice one!
Old 03-25-2012, 6:14 PM
Wiki Admin Emeritus
If you're talking about the ones shown here...
Common Public Safety - The RadioReference Wiki
The 164 won't decode them - they're P25...Mike
co-author, HF Digital Decoding
Old 07-19-2012, 3:11 PM
joannedwards's Avatar
I Have forgot how to change firmware on my 164 pro,i have win 97 but cant open their files can you help me out? thanks joann edwards
Tags
pro 164, programming software
