CPU 1.7 firmware Release
Radio shack has released the CPU 1.7 firmware upgrade for the Pro 106 and Pro 197.
The current RS site links are not formulated properly, but the firmware is able to be downloaded. I have downloaded and installed it to be sure the upgrade worked before I posted this thread. The Links to the upgrade and PDF are posted below.
New features:
New DSP Boot code V1.1 to handle a different Flash IC version. There is no user-noticeable performance change.
New features:
- Change S-E GLOB "138-174 5kHz:" item to "Bandplan:" with a choice between USA and Canada.
- Change step size to 12.500kHz in 405.987500-512.000000MHz range when the "Bandplan: Canada" option is selected in the FUNC-GLOB menu.
- Change step size from 12.500kHz to 6.250kHz between 470.000000MHz and 512.000000MHz to handle the new UHF bandplan.
- Further qualify EDACS "Individual" call grants to address a problem where the radio sometimes tunes to MDT transmissions as radio-to-radio calls.
[*]Fixed EDACS "channel number" in CCDump messages.
[FONT=Arial,Arial][FONT=Arial,Arial]Download:[/FONT][/FONT]
