Not too sure what to say, thank you for all the help and advice. I even did a limit search with the pro 433 scanner and my pro 106 scanner. My scanner finds the right frequencies but the pro 433 doesn't. Mine will find the frequency 858.6625 but the pro 433 will find 858.675, I've made sure I am in E2-800 as per page 24 of the manual but it doesn't seem to help....
It definitely should allow you to enter those freqs. Here are the specifications from the PRO-433 Service Manual. Try re-setting the memory, page 38.
GENERAL
1. Band Coverage: 18 Bands
2. Frequency Range
Conventional Mode:
[Range] [Step] [Mode]
29.000 to 29.995 MHz 5 kHz FM (10 Meter Amateur Band)
30.000 to 49.995 MHz 5 kHz FM (VHF Low Band)
50.000 to 54.000 MHz 5 kHz FM (6 Meter Amateur Band)
108.000 to 136.9875 MHz 12.5 kHz AM (Aircraft Band)
137.000 to 143.995 MHz 5 kHz FM (Military Land Mobile)
144.000 to 147.995 MHz 5 kHz FM (2 Meter Amateur Band)
148.000 to 174.000 MHz 5 kHz FM (VHF High Band)
179.750 to 215.750 MHz 6 MHz WFM (VHF TV Band)
216.000 to 224.995 MHz 5 kHz FM (1.25 Meter Amateur Band)
225.000 to 399.9875 MHz 6.25kHz AM (UHF Aircraft Band)
400.000 to 419.99375 MHz 6.25 kHz FM (Federal Land Mobile)
420.000 to 449.99375 MHz 6.25 kHz FM (70 cm Amateur Band)
450.000 to 469.99375 MHz 6.25 kHz FM (UHF Standard Band)
470.000 to 512.000 MHz 12.5 kHz FM (UHF TV Band)
806.000 to 823.9875 MHz 12.5 kHz FM (Public Service Band)
849.0125 to 868.9875 MHz 12.5 kHz FM (Public Service Band)
894.0125 to 956.000 MHz 12.5 kHz FM (Public Service Band)
1240.000 to 1300.000 MHz 12.5 kHz FM (25 cm Amateur Band)
