Programming a Motorola Type II Smartzone w/APCO-25 (rebanded) on a Pro-106
scanner92
Hey all,
I just got a new RS Pro-106 and I am having the hardest time setting up this system. I am fairly new at this. The preprogrammed data for this system (Gainesville/Alachua County) is all wrong and will not scan. Someone please help me program this; im all confused (the rebanding does it make it any easier):
Gainesville / Alachua County Trunking System, Gainesville, Florida - Scanner Frequencies
or
System Name: Gainesville / Alachua County
County: Alachua
System Type: Motorola Type II SmartZone
System Voice: Analog and APCO-25 Common Air Interface
Last Updated: January 26, 2011, 8:05 pm (Updated Talkgroups (1 Updated))
Collaborate
For more information about this trunked system please see this entity's Wiki page:
•Gainesville / Alachua County Wiki Page
To discuss information online about please see these forums(s) in the RadioReference.com Forums:
•Florida Radio Discussion Forum
Important Rebanded Note
One or more sites for this trunking system have gone through the 800 MHz rebanding process. Your scanner may be incompatible, require a firmware update or require special programming to track these sites. Please visit the RR Wiki Rebanding page for additional information.
System ID List
System ID Connect Tone
7B2D 138.46
Misc System Information
All of Alachua County and the City of Gainesville Public Safety has moved to this ASTRO Smartzone system. Most if not all communications on this system are in APCO-25 Digital mode. The system is actually run by the Gainesville Regional Utilities (GRU).
To be able to monitor this rebanded system with Uniden scanners (996T, 396T, 396XT, etc), you MUST use a custom Band Plan. The default settings recommended by Uniden work: program in the control channels, then edit the band plans by setting Band Plan 1 and Band Plan 2 to this (BOTH band plans MUST be entered): Band Plan 1: - Base (lower) = 851.025 - Base (upper) = 854.000 - Offset = 440 - Polarity = + - Spacing = 25-KHz Band Plan 2: - Base (lower) = 851.0125 - Base (upper) = 868.9875 - Offset = 0 - Polarity = + - Spacing = 25-KHz Without these settings, the scanner will not go to the correct voice channels, especially when the control channel itself is on a splinter frequency (like 853.775).
System Frequencies
Red (c) are primary control channels | Blue (a) are alternate control channels | Site Map(s): FCC Callsigns RR Locations
Site Hex Name Freqs
001 1 Simulcast 851.08750 851.13750 851.18750 851.41250 851.63750 851.66250 851.77500 851.91250
852.05000 852.18750 852.27500 852.30000 852.41250 852.56250 852.68750 852.77500
852.81250 853.06250 853.11250 853.18750 853.31250 853.36250 853.52500 853.56250a
853.67500a 853.77500a 853.81250c 853.86250
Macomb, Michigan
Check in the Florida forum there should be somebody there that can help you get up and going. Florida Radio Discussion Forum - The RadioReference.com Forums As for a custom band plan I do not know if you need to put one in for the PRO 106 because it does for you sometimes depending on the type of system.
If I need to I will make a step by step how to program your PRO 106 which I have done for many others with success usually. It on't be until later because I have school in about 5 hours and I am tired at the moment. Don't worry there is a lot of knowledgeable people on here and will help you.:)
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Set T-Tables as follows
Setting T Tables for rebanding
1. PGM
2 .F2 Edit
3 ► to TSYS under F3 then press F3
4.▼ to your system then F2 Edit
5.▼ to T Tables
6. ► to Custom then SEL
Code:
L0 Chan	Hi Chan	Offset	Base freq	Step
440	559	440	851.02500	25.0
0	719	0	851.01250	25.0
720	759	0	848.00000	25.0
815	831	0	846.62500	25.0
958	958	958	868.97500	25.0
961	1022	0	843.40000	25.0
scanner92
OsloViking, if you could that, would be great. I tried the t table thing, and still nothing. The manual isnt very good. Dont know whether to choose P25 Auto or Manual. Put in the CC and alt CCs? And then it asks something about multi site networking???
Thanks much
South Central Minnesota
I would use P25 Auto...As far as multi site, are you using the scanner stationary or driving around in your car? I don't know your specific system, but if there are multiple sites, and you are driving around use the ROAM setting, if stationary use the stationary setting.
redhelmet13
4 nm se KNFW
If this is a mixed mode type II system, do not use P25 instead select 800/900 since the control channel is 3600 baud. True P25 systems are 9600 baud.
fmon
Eclipse, Virginia
Motorola Type II SmartZone is his system, set to MOT800/900, enter these control 853.5625 853.67500 853.77500 853.81250 freqs and set the 6 T-Tables.
Edit: A Group Wildcard is required if no TGRP Objects are entered
Macomb, Michigan
Thanks all, for your expertise. You were great help. I got it to work!
Great News, Glad we all could help you. As I said there is plenty of knowledgeable people on here. If you need any more help let us know and we will try to find an answer for you.:)
So how did you like programming it manually? I myself enjoy it because I believe you gain more of understanding how it works and if you have software and it fails possibly you know you can program it manually.
