Hello Gang,
I have been messing with a brand new Pro197 for a week now... The P25 digital system that I have programmed in is very choppy. I have only the control channel for Butler County and Sedgwick County, Kansas programmed in the thing, and the signal strength is a full 5 bars. I have set TGRP's and have set the Wildcard and it doesn't matter. Have also tried some things from Radioreference.com, such as setting system to Roam and Stationary, turning on Digita AGC and Turning on "Check All CC" to no avail. Also have downloaded the programming stuff from rr.
When the 197 is on the system it seems as though it is not decoding correctly. It stops on the TGRP's and sometimes opens up on them, but it is always very choppy. Once in a great while, I will get a good strong lock, but rarely. I am running on a Kansas State 800 MHz digital simulcast system and I am sure the control channel is correct. It is also not a priority issue. I was running into the same problem with Pro-106's that I was programming... On my 996XT, there is an RSSI setting that is deep in the software that I changed to make it pickup better and it does not seem to have the problem the RS does...
I am less than 5 miles from one of our sites and we have tried several different antennas too.
Please - any help at all??? I have a Uniden 996XT and it does not do this???
THanks
Chad
THanks
Chad
