The RadioReference.com Forums
-   Radio Shack Scanners (https://forums.radioreference.com/radio-shack-scanners/)
-   -   Pro-95 speaker mod? (https://forums.radioreference.com/radio-shack-scanners/221776-pro-95-speaker-mod.html)
kf5jmd 09-18-2011 10:10 AM
Pro-95 speaker mod?
Hi, new forum user here, not new to scanners, or any type of radio equipment, but I do have a question about this scanner, the Pro-95 older model dual trunking from Radio Shack....
I remember programming one of these years ago for someone, and the audio is not very loud from the internal speaker. Does anyone know what replacement speaker or some other mod (like maybe a higher gain transistor for the audio output circuit and it's location on the circuit board)?
Just thought I'd ask, I got one the other day off Ebay for $61 shipped. Figured couldn't pass that up, I don't often need a handheld, but lately with the wildfires here in Texas it would be nice to have a handheld. This county is still on TxWARN Analog 800mhz Motorola Type II Smartzone so the Pro-95 will work just fine for that.
Thanks in advance!
Chris
KF5JMD
DickH 09-19-2011 7:23 AM
Originally Posted by kf5jmd (Post 1613855)
... the audio is not very loud from the internal speaker. Does anyone know what replacement speaker or some other mod ...
Adding a jumper to bypass the audio limiting resistor should boost the audio.
http://dickh.zenfolio.com/img/v15/p582679332-3.jpg
KC5EIB 09-19-2011 9:46 AM
I have done this mod for using an EXTERNAL speaker and it works great. If the internal speaker has gone bad, a replacement is available from places like Digikey or Mouser
pro92b 09-19-2011 10:02 AM
The internal speaker has no limiting resistor. The resistor you referenced is only connected to the earphone jack. The audio amplifier chip is a type NJM2070 powered by a 5 volt regulator. It can only ouptut about 0.3 Watt of audio power so the volume capability is limited.
