I am having trouble getting my local PD / Sheriff frequencies to come in clearly. The two freqs I am having trouble with are 465.1000 and 465.3000 . They do not seem to be listed in the RR database. Jefferson County, Iowa (IA) Scanner Frequencies and Radio Frequency Reference Many that are listed for the county, even under Licenses, FCC Licenses and Scanner Frequencies for Jefferson County, Iowa (IA) seem to be unused. Maybe they are digital. I found these two by searching the FCC site. Site / Market / Frequency Query I hear them very faint and with a lot of white noise just enough to make out what they are saying, both dispatcher and mobiles, but my Pro 163 indicates a full signal. It sounds like a distant signal. I have tried different antennas with no difference at all. I am using a WBD-40 Discone. I have determined they are CTCSS, and I have the two frequencies set to that mode. When receiving the scanner shows the CTCSS code as 131.8 . I have the attenuator off. I should note that I receive these two frequencies about the same using my Po 404 with the stock rubber duck. I am about 9 blocks from the tower listed on the FCC site for these frequencies. I receive other freqs even in the same frequency range fine. I am in Fairfield, IA – Jefferson County. I am fairly new to scanning. Any ideas?
