ETMegabyte
I have 2 scanners hooked up to the antenna on my roof. I also have a 2m/440 ham antenna up there as well.
One scanner is the Pro-197 that I use for RR streaming, and the other is a Pro-2046 that I primarily use for scanning ham frequencies. This is a fairly new set up, as I just recently got the scanner antenna up on the roof.
My issue is that the Pro-197 appears to be working just fine, but the Pro-2046 seems to have weak receive. If both the scanner and my ham radio are listening to the same frequency, even local repeaters appear to have low signal into the scanner, while they are full quieting on the ham radio. And sometimes, a conversation will be happening on the local repeater, and it appears to fade in and out on the scanner, but comes through nice and clear with full signal on the ham radio.
I tried changing the antenna cable from the splitter to the scanner, and that didn't fix it. I don't know what to do. All the scanners I've had in the past simply worked until they didn't work. This seems to be somewhere in the middle? Has anyone ever heard of this?
