Old 07-26-2017, 12:52 PM
WhistlerWendy's Avatar
Whistler Representative
Smile Repair program for Pro-668
Whistler is now offering a repair program for the Pro-668.
The cost of the program is the same as our Whistler out-of-warranty scanners - $120.
If you are interested in having a Pro-668 repaired, please contact our customer service department at 866.923.8719.
Old 07-26-2017, 3:07 PM
Default Well done Whistler!
Job well done on offering to fix scanners that have been locked for $89. Because of this turn of events I plan on sending in my unlocked scanner for $59 upgrade. Again, very well done!
Old 07-26-2017, 3:13 PM
So the main difference between the 60 and 90 upgrade fee is if the unit is locked.
I ask because i have 4.5 and 3.x in mine. I was shooting for better P25 decoding and felt that worked best for me. So my unit has modified software but is not locked.
Based on that im guessing i need the 60 service. Correct.
Old 07-26-2017, 3:18 PM
Yes that is correct.
Old 07-26-2017, 5:41 PM
Better flash it back to Radio Shack before sending it in.
Never know if Whistler might update the dsp and date then charge you $90 once it is on their hands.
Pro-668 WS1095 Bcd436hp
Old 07-26-2017, 5:46 PM
scosgt's Avatar
WAIT.
This says "repair service. It says NOTHING about unlocking.
Old 07-26-2017, 6:21 PM
Originally Posted by scosgt View Post
WAIT.
The post I read earlier was pretty straight forward.
Fully functioning scanner can be upgraded for $59.99
Locked scanner due to unauthorized use of Whistler FW will require a pcb change and be updated for $89.99
Any PSR-800 or Pro-668 not in service and not locked due to unauthorized use of Whistler FW will be repaired and updated for $120.
You may want to read the official post Wendy made earlier today, I saw it on the Whistler Forum.
Old 07-26-2017, 6:26 PM
JustLou's Avatar
WAIT.
https://forums.radioreference.com/ra...-scanners.html
Old 07-26-2017, 6:29 PM
fredva's Avatar
I think the point being made by scosgt was that this may be the wrong thread to talk about the pcb change. The $120 repair service is a separate charge, separate operation from that offer.
PRO-18 upgraded to a WS-1080, PRO-197, PRO-2020, PRO-2021, 436HP, Raspberry Pi SDR
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 07-26-2017, 6:46 PM
cebowman
Guest
Posts: n/a
$120 Total Period w over hull.
Support + Service = Total of $120
$59.99 OEM Firmware + $60.01 to Refurb Whole unit
$89.99 Whistler "Time Bomb" Models + $30.01 to Refurb Whole Unit
Service
$120 for Non-working at all, models including Radio Shack PRO-668 and GRE PSR800
What about Radio Shack Pro-18 models and GRE PSR-700's?
Old 07-26-2017, 7:05 PM
Additional clarifications from Wendy:
https://forums.radioreference.com/gr...ml#post2795875
Old 07-26-2017, 8:36 PM
fredva's Avatar
So apparently it doesn't have to be a separate charge, in the case of a covered repair and an upgrade done at the same time.
Old 08-22-2017, 5:15 AM
iampaige86's Avatar
Default Thank you
Thank for this info. I think I might also send my scanners over. This will saves me a lot over repairs and unlocking.
Tags
sticky
