nonionizingemf
Just received my Realistic Pro-2006 from ebay. I think I may have paid a little much for having the battery beep issue and not knowing what the mods are and if they're working.
However, the system is decked out with the mods and I was told the scanner is working and appears to be though I haven't connect to a better antenna yet.
Here is the eBay link: Realistic Pro-2006 400 Channel WX Fire Police Hyperscan Scanner works | eBay
You can select the right arrow for more images of the case open.
I've attached two images of the chips I found inside if that help with identifying the mods.
Any help would be greatly appreciated as I am most interested in how to connect to the computer using the DB25 serial connector in the back.
