Has anyone with this scanner had the com port fail? Used to be anytime I plugged in my 668 to the computer the led light on the scanner would stay on all the time, It was programed to do that under settings. Now when I plug in the scanner to the computer the scanner led never comes on and when I try to connect to the scanner thru IScan program it doesn't ever detect scanner. I've had this scanner maybe 6 months and it has always worked very well with the iscan software program until just recently. I tried several other cables and even ordered a brand new cable but that didn't fix the issue. It's not the cable. When I check Device Manager and look under Universal Serial Buss controllers or devices I don't see the pro668. Can I try and reload the driver?? Not sure how. The scanner is still very usable as is since I can still do all the programming I need to with Iscan and the micro SD Card and can recharge batteries with external charger. But now I can't send it into whistler for ws-1080 conversion since the com port isn't working and I can't do any firmware updates.
Any suggestion on how to verify for sure that my com port is shot?
Appreciate any help at all
Larry G
Larry G
