Old 02-25-2018, 11:04 AM
Exclamation what program to use to upload to scanner
what programs can i use to upload to my pro 106? im thinking about buying a premium subscription so i can upload to my scanner. is it worth it? im going to want anything in raytown missouri on my scanner. i want to listen to things other than police/fire/ems is that possible? any guides on how to upload using the software program too? thank you
Old 02-25-2018, 11:13 AM
You can use Butel ARC-500 software to program that scanner. It has RR support.
The Pro subscription is more the worth it. It's pretty easy with the software.
Old 02-25-2018, 11:38 AM
$70.00 is a little steep for me right now, is there anything cheaper that you know of? something that comes with the subscription from RR?
Old 02-25-2018, 11:50 AM
InlandAZ's Avatar
Try WIN500, $30.00 - Win500: WS1040, WS1065, PSR-500, PSR-600, PRO-651, PRO-652, PRO-106, PRO-197, PSR-310, PSR-410 Scanner Software for Data Management, Monitoring, and Control
Old 02-25-2018, 11:51 AM
There is no software programming that comes with the RR premium subscription.
The 3 choices of software packages for your scanner that will use the Web Programming feature of the RR premium subscription are WIN500, PSREdit500, and ARC500.
They all have free 30 day, fully functional, trial periods.
Old 02-25-2018, 12:53 PM
iMONITOR's Avatar
PSREdit500
is my favorite. It's not free, but it does have a free 30-day trial period. After that a license it only $35.
PSREdit500 - Configuration Editor for the PSR-500, PSR-600, PRO-106, and PRO-197 Scanners
Old 02-25-2018, 3:40 PM
2nd on ARC500 very easy
scanning the pinelands of south jersey bcd436hp pro651 pro652 pro2006 pro2096 grundig satellit 800
Old 02-25-2018, 5:04 PM
I like Win97 for the Pro-163.
In your case it would be Win500. I haven't used Win500 myself so I don't know if there are major differences.
Old 02-25-2018, 5:34 PM
Wiki Admin Emeritus
Incorrect; We have a deal with BuTel where RR resells ARC500, and when you do this, you get 2 free downloads for a period of 7 days. See the following links for more information;
https://www.radioreference.com/radioshack/?a=order
Radio Shack Programming Software Free Trial - The RadioReference Wiki
I have often wondered why Lindsay didn't trumpet this when the deal was made, and has made the page a bit tough to find. Mike
Old 02-25-2018, 5:40 PM
Wiki Admin Emeritus
blue4x, you can find links for the 3 programs that are compatible with your 106 - ARC500, PSREdit500 and Win500 - here...
Object Oriented Scanner Software - The RadioReference Wiki
Note that there is also a documented way to run some of these programs under Linux, if you happen to be under that environment
Tags
pro 106, software help, software installation, upload to scanner
