Eshort
Took batteries out and stored scanner for 3 months in plastic bag.
Worked fine when packed away.
After 3 months..scanner won't work..it runs thru the initialization and then stalls on a page displaying all the icons..Does not respond to any keys..must pull batteries to turn off.
Trying new batteries/running on as power supply makes no difference.
Removed and cleaned as card..no change.
Strange that problem occurred after careful story g for 3 minths.
Any suggestions re..cause/cure
Who is a good repair facility..good= fast competent service.
Thanks....
Ed
Thanks....
Ed
