Racing Scanner PRO-444 Microphone Issue
Stryker1435
I have a Radio Shack Racing Scanner, PRO-444 and trying to be able to communicate between two headsets using the microphones and earpieces. I got Radio Shack microphone headsets and plugged them into the A and B ports. I can hear static in the headsets and when I hit the PTT button I hear an interruption in the earpiece, but I do not hear anything from the microphone. I tried a few headsets with the same results. Anyone have any suggestions?
GeneseeCoMI
Mount Morris, Michigan
Scanners don't have microphones but they can't transmit, they only receive. You can use a pair of headphones to listen though. If you want to transmit, you'll need a transceiver. Some bands you'll need a license (amateur, GMRS) and some you don't (CB, FRS, MURS, marine).
Stryker1435
This model has A and B ports, each including a 2.5mm and 3.5mm port for a microphone and earpiece setup. With microphone headsets in both ports it says you can talk to the other person. I did not have a race tuned in the scanner and wondering if this is the cause.
GeneseeCoMI
I see there's an "intercom option" whatever that means, that must be what the mic jacks are for. The manual doesn't really explain it though.
https://fccid.io/ADV0704/User-Manual/User-Manual-1290303
Again this radio does NOT transmit, it is clearly labelled as a receiver.
Stryker1435
I assumed the communication would be done internally through the scanner. There is another port on the scanner for a "Phone". You can insert a 3.5mm prong in the phone and also the scanner to talk on the phone. But this is a different port than the mic/headphone.
The manual doesn't say a whole lot. Does anyone have this scanner and mic/headsets that they use?
GeneseeCoMI
I don't know this for a fact, but I'm guessing you can somehow hook the headset up to your phone and the scanner to amplify the audio for phone calls via the scanner's speaker since races can get pretty loud.
wtp
Port Charlotte FL
try reading this one
file:///C:/Users/QQQQ/Downloads/Radio_Shack_PRO-444_User_Guide.pdf
well i'll be
it does say to push the PTT button to talk to another person...
GeneseeCoMI
well i'll be
The manual that I posted above (which calls the radio a receiver) says:
"Connect the Mic and Headphone twin jack into Intercom A or B jack. If you connect A jack, you
can talk with the mobile phone call".
So apparently you need a cell phone to talk to someone else. By just using the radio itself you can't.
garysvan
the way they work is if you connect 2 sets of headphone/mic units into the A and B jack sets on the same radio 2 people can talk to each other like a intercom at a loud racetrack.
he probably just does not have the correct ones to work with the radio i am surprised the manual does not list the compatible headsets to use they can be wired differently or have the wrong mike elements so who knows.
