PRO 96 Yellow Battery Holder
n2pqq
Any ideas on where to get the yellow holder for rechargeable battiries cat Number 1222805. Radio Shack 1-800-843-7422 says item not in stock no parts available for this radio.
Anyone ?
KE5BCP
Analog Man
Lewisville, Texas
Anyone ?
I believe these must be ordered in-store now using "RS Unlimited".
n2pqq
I went to my local Radio Shack and was able to order the part >
Oh well .
stvnd53
Banned
Toms River,NJ.
FYI: There is a simple Mod.you can do to make the black holder good for regharging batts.
hcpholder
I went and ordered the "yellow" holder from the store. Just $5 bucks, no need to mess up warranty!
Steve73
Southern Indiana
I ordered the black holder awhile back by calling this number 1-800-843-7422 (same as you have). Here is the recharge holder info. Catolog # 12228805 , part # HB90252.
Steve
jleverin
you should be able to get it from the RS store. I bought my yellow holder and rechargeable batteries when I bought my scanner.
nicdoot
Tampa, FL
yellow battery holder
Do you mean the rechargeable batteries go in the yellow plastic case and then into the scanner?
I have an adapter so I don't use rechargeable batteries.
n2pqq
Please check page 25 and 27 of your owners manual.
Hope this helps.
LEH
Yorktown, Virginia
you put them in a round house and tell them to pee in a corner :lol:
Now that might work, but I'd just turn around and use the nearest wall.
Actually I was referring to stvnd53's post that there is a mod, but he has yet to post what the mod is. He's still got us in suspense (or just suspended).
N1SQB
Somewhere On Earth
The suspense is OVER......
what is the mod?
Personaly, I prefer to use an external stand alone charger (MAHA). However, if you are so inclined to charge internaly, here you go. I found this online so I can not say if it works or not:
"Black" Battery Holder Modification
If you don't have a stand alone battery charger for your extra rechargeable batteries, or you've lost or broken the yellow battery holder, you can modify your radio to recharge your batteries with the black holder. Remember, don't plug your radio in if you're using alkaline batteries in the black case after completing this mod.
Open the battery door, and remove the batteries and holder.
Remove the four screws located on the back of the case.
Carefully pry the back half of the case off.
Locate the three metal strips at the bottom of the pc board on the right hand side.
Locate the two strips spaced closest to each other, and solder a jumper to these two strips.
Reassemble the radio in the reverse order you disassembled it.
You will now be able to recharge batteries using the black holder. Again, use only rechargeable batteries with this mod. If you attempt to recharge non-rechargeable batteries in your radio, you will cause the batteries to leak or explode.
Manny
jleverin
Hey, I have a pro-82 and a pro-97 and the battery holders are the same fit for the pro-96 so any yellow battery holder for a RS scanner should fit your 96. I have all three and they fit interchangably.......
