I'm glad to see others are interested in this radio system. I think it's really cool because there's a lot more activity to be heard on LACMTA channels than normal heavy rail channels, especially since this network is a repeater-based network with multiple sites., and thus can be heard anywhere in the range of one of the powerful towers.
Here are a few things I've learned about the system for those who don't know:
-The trains have ICOM F-5061D Mobiles. Mobiles usually have four-digit ID numbers starting with 3 and 5. A notable exception is Gold Line train car 710, which has an ID number of 710.
-Handhelds used are ICOM F-3161DS and F3261DT portables. All of the 3261's are configured with the full keypad; all of the 3161's are configured with the limited keypad. They often have four-digit unit ID numbers starting with 1 or 2. If they don't, they have 3 digit id numbers.
-Mainline control's ID number is always 20.
-Rail supervisor vehicles are also equipped with a mobile radio, and in addition, they have a mobile/base Uniden BearCat scanner.
-This is a "voting" system. The reasons for the multi-casts (same audio heard on multiple frequencies) is because the radios are constantly measuring the signal strength of each repeater site and changing to the appropriate frequency to optimize coverage (presumably the repeater with the greatest signal strength). This allows "roaming" and one "channel" to be used along a long stretch of railway.
-The reason I have a channel in quotes is that, with the exception of perhaps Foothill, Downtown, and the yard channels, the channels are actually programmed as zones. Each channel is a zone, and all of the frequencies in the zone are evaluated by the user radios and one is selected as stated above.
-The "10-codes" used on the radio is different from the 10-codes you'll hear police using. Metro has their own set of codes that I will not make public, but if you listen enough you can figure them out.
Additionally, while listening to @glradio 's stream, you'll often hear control calling different employees. Employee names are not used... instead, they have callsigns they use on the radio. (Ex: Gold Line control to S42 means Gold Line control to the supervisor assigned to S42).
Here's a quick callsign reference, showing the first letter of the callsign and the employee's position:
T - Train Operators
S - Supervisors
MT - Track Inspectors
MS - Signal Inspectors
M - Vehicle Technicians
L - Elevator Technicians
R - Dispatchers and Supervisors
TP - Traction power employees
FM - Facilities maintenance
I hope someone finds this useful. 73!
