Go Back   The RadioReference.com Forums > Service Specific Monitoring > Railroad/Railfan Monitoring Forum
Railroad/Railfan Monitoring Forum - This is the place to discuss monitoring railroad communications.
Old 09-21-2018, 10:38 PM
Default Newbie Frustration
I picked up a Uniden BC125AT and programmed in the BNSF frequencies for Denver, CO. For what it's worth, I live in central Denver, about a mile east of the BNSF Joint Line.
Well, I took the scanner out tonight and biked to the 8th Avenue bridge, which crosses over the tracks. I had my scanner on the whole time. All I heard was occasional static and rare voice traffic , most of it unintelligible.
There was very little going on. Anyway, I'm on the bridge, waiting... I'm up pretty high, over the tracks, near downtown, so I would imagine that I would have a good signal.
After about 10 minutes a loaded coal drag passes under the bridge. There was nothing on the radio that suggested that would be happening.
Obviously I am doing something wrong. Any suggestions? Many thanks.
Old 09-22-2018, 9:02 AM
Also, it doesn't seem like I'm able to edit this post - I wanted to also mention that the squelch is adjusted as it should be.
Old 09-22-2018, 11:30 AM
krokus's Avatar
Just because the train is in motion, does not mean there is a radio transmission. They are used moreso around switching yards.
Some trains are now using digital modes, are you sure that you were not hearing that "noise" instead?
Sent using Tapatalk
Old 09-23-2018, 12:10 PM
Up here in Wyoming, radio chatter is mostly switching cars,loading, unloading, or track information. As you are close to the tracks,I would suggest just leaving the scanner on when you are home. An outside antenna would ensure reception but a mile from the tracks you should be fine. As already mentioned, it is not constant chatter and a week or so of scanning should let you know if you want to continue.
If radio traffic is light,I suggest you program all the 'channels' used by railroads as they may be using other channels. If you 'find' them submit the data here so the database can be updated. That's what RR is-people reporting frequencies so others can use the information.
Have fun
Old 09-24-2018, 6:23 PM
fire_master_21's Avatar
As a conductor we don't always use the radio for things. Usually DS will give us updated info for slow orders, at grade crossing gate malfunctions, weather warnings and such. If you are in an area controlled by CTC, the train crews will operate on signal indication. I can go my entire trip almost 300 miles and never talk on a radio, some days it seems like I am talking and copying all the mentioned above items.
Motorola APX7000 VHF/UHF FPP
Motorola XTL5000 VHF P25
Kenwood Tk-5710H P25
Old 09-24-2018, 9:43 PM
Many thanks, everyone.
Old 09-25-2018, 7:56 AM
do you guys not call signals out there?
Scanners: BCT-15, Pro-106, Whistler 1040
Radios: Icom 3161, Connect Systems CS580
John 15:13 - Greater love hath no man than this, that a man lay down his life for his friends.
Old 09-25-2018, 12:18 PM
only if riding on UP track.
Old 09-28-2018, 1:48 AM
BNSF doesn't. UP only acknowledges less than clear over the radio.
A case-and-point is the UP Overland Route across Wyoming. A constant parade of trains, but outside of Cheyenne Yard and the stop for fuel at Rawlins, there is very little radio chatter. Detectors talk on defect only, and maintainers get track and time over the phone.
Old 09-28-2018, 4:29 AM
spdfile1's Avatar
Another thing you could do is figure out the closest defect detector to your location on the line your wanting to listen to. That will allow you to see if your monitoring the right frequency and if your a little ways from it or out of site of it but can still pick it up it'll give you a heads up of what's coming. Also stick in 452.9375 & 457.9375 which are the E.O.T. (End Of Train) device frequencies. They are low powered data transmissions from the head end to the F.R.E.D. & vice versa and are a great way to know a train is coming before you see it. However in a yard setting they are useless cause your picking up multiple signals from multiple trains lol!!!!!!!
N4SYR (nee-KC2PBB)
Old 10-12-2018, 4:23 PM
KC9LQV's Avatar
You may want to carefully verify your frequencies. I listen to the BNSF Joint Line scanner feed from RailroadRadio.net often, and usually there's so much talk you can't keep it all straight.
RailroadRadio.net - BNSF/UP Colorado Joint Line (Updated)
You might try that feed for a few days to get an idea of what to expect.
Also, if you plan on just using your scanner for railroad monitoring, you may want to consider getting a slightly higher-gain antenna tuned specifically for the railroad band. The ones sold by Smiley Antenna are quite good.
Old 10-27-2018, 12:01 PM
Have you checked out the frequency database?
Here in northern NJ, I monitor mainly CSX, but have all of the local rr's programmed into my radios.
CSX calls out every signal regardless of display, and they have defect detectors that transmit on the road channel.
I use a Yaesu/Vertex VX-150 (2m transceiver) and a Yaesu FT-60R (2m/70cm transceiver) for monitoring railroads. I have an outdoor antenna (a Cushcraft ARX-2B) about 30ft up, and can receive signals as far as 30 miles away, but that depends on several factors, including train's radio/antenna, location/terrain, weather, and time of year (foliage).
In Denver, you should have no trouble at all hearing signals from the east, but from the west it would be very difficult to hear anything beyond the foothills of the Rockies.
As was already said, class 1's are CTC, so, unless they are required to call out signals, they don't require use of the radio unless there is a train order, change of route/track or an emergency.
You should be able to pick up the defect detectors, although most of them transmit very low power, so are limited distance for your receiver.
CSXCP55
Old 10-28-2018, 6:52 PM
sking128's Avatar
If you have the Freq's correct, you should be hearing a lot of things. The Joint line uses TWC from Littleton all the way to Pueblo. Not to mention, you should be hearing a bunch of Yard traffic. You mentioned you were listening from a bridge. What was your location? BTW, Neither BSNF or UP are using digital transmissions here in Colorado.
Old 10-28-2018, 10:58 PM
AnalogLowband's Avatar
You are getting excellent advice here, especially from those in the business. I program the entire AAR band-plan just in case frequencies change. I also program all the UHF frequencies in a separate bank so when things quiet down considerably on VHF I combine the VHF and UHF banks for EOT or those annoying switch control data signals on VHF, both of which will at least let you know your radio is working. I do this with aviation stuff too. I don't do ATC but only airline company voice frequencies exclusively. ACARS goes into a separate bank and I combine that bank after the Red Eyes arrive and depart and I am not watching FlightRadar24. Take care.
Cobra 19 Ultra III and Uniden Pro401HH on 19AM 27.185 MHz
