That's interesting. I assumed that terminal #1 was only for the coax shielding, and never thought to attach the wire from my ground rod to it. Think I will try this to see if terminal #1 reduces noise better than terminal #2, where I currently have the ground wire connected.
Have you used either terminal to shield the 293 cable outer shield? I have tried it both attached and unattached to #1 and can't decide whether it helps or not.
I'm also thinking of running a thin cable from the grounding connection on the back of my Icom R75 (to be replaced soon with a JRC NRD 545, woo hoo!) to either terminal 1 or 2 act as a ground for the radio to see if this reduces noise.
Suzie
Well that is the trick. Try all configurations to see what works for your particular situation and location. As you notice in the documentation terminal #1 is actually the shield side of the SO-239, in other words, it is the shield of the coax you use to feed the antenna. You don't need to attach anything to the shield (or outer shell of the PL-259 which screws into the SO-239). The shield of the coax is already connected inside the plastic block to terminal #1. Further, terminal #2 is the ground side of the 9:1 transformer inside the plastic block, and of course terminal #3 is the antenna side of the 9:1 transformer - and where the antenna wire attaches. But please note, that in my particular case I removed the jumper wire between #1 and #2. If you leave it there, then there is no difference between connecting your ground rod to either #1 or #2. You have to remove that jumper to isolate the two respective terminals from one another in order to test which grounding point gives you the most noise reduction.
I would be very surprised if running a ground wire from the back of the R75 to the terminal block of the antenna would help, but it never hurts to try. My configuration is as follows:
The antenna is configured as a sloper, with the transformer end away from the house. There is a ground rod sunk next to it, to which I have a very short jumper to terminal #1 on the plastic block. For feeding the antenna, I am using buriable RG-6 quad-shield coax for the first section of my run. It goes underground (I did this because my feedpoint is at ground level at a point away from the house and I wanted to keep it out of the way of people and the mower) for about 45 feet from the feed point, where it comes out and goes to a grounding block. I have a second grounding rod in at this point, and the grounding block is connected to it via a very short wire. On the other side of the grounding block I have regular RG-6 quad-shield cable that runs up the back of my house to a second floor room where my Drake R8A is. So as you see, I actually have two ground points. One at the antenna feed point, connected to terminal #1 of the plastic block, and another where the underground coax feed comes up and transitions to a second run of coax into the house. I do not have a ground connection from the back of my radio. Since it is on the second floor, the ground lead would be way to long to be of any use. You want to keep ground leads as short as possible. By having two grounds in the feed-line path, my goal is to provide increased bleed-off of any static build up on the antenna, as well as trying to make my antenna as low noise as possible. I am in a sub-division, and it is fairly noisey here. But, by playing with my grounding scheme, I have been able to lower that noise floor to the best I've ever had.
With all that said, I still disconnect my coax from the back of the receiver when I am not using it just to be on the safe side. You will note that I am using 75 ohm coax rather than 50 ohm. In reality, for receiving purposes, that will make little to no difference in the reception quality. The reason I went with RG-6 is because I could get high quality, smaller diameter cable for less cost, that would mate up to the TV-type grounding block I installed at the foundation of my house. Since RG-6 comes with F-type connectors, I am using an F to UHF adapter to mate the cable up to my Drake, and also to the SO-239 connector on the plastic block at the business end of the antenna.
I hope the above makes sense. While I know what I mean, I am not always sure that what I mean comes across in my writing. Let me know if you have any questions. Good luck.
