Today i finally got the g5rv up on the roof (2 floors up) and i was using a peice of wire before in the same space the g5rv is in. I have it in an inverted v configuration and for some reason i get a ton of noise almost across all the bands. I had the g5rv at ground level and did not get any noise/rfi. Here are some pictures of HDSDR notice the vertical lines every 5khz or so. what am i doing wrong? im not using a balun/unun or anything like that. Just rg6u to the ladder line
10khz
15khz
6khz
10khz
15khz
6khz
