First off, many thanks to those of you with Wellbrook and Pixel RF Pro-1A and 1B models for all of the information that you've provided regarding loop antennas. I "think" I am ready to take the plunge and get one.
I currently use an RF Space SDR-14 for SWL'ing (its primary use has been as a panadapter for my AOR AR5000A+3) in conjunction with SDR-Radio software. For an antenna I am using a Par EF-SWL that runs from about the 35' height of my tower, which is bolted to the right side of my house, directly over the roof of my 1 story ranch to a mast that is side mounted on the other end of the house. The property is a 1/4 acre lot that is surrounded on all sides by similar 1/4 acre lots. I expect that in most of these houses (and my own) numerous appliances that generate man-made noise are running constantly, especially during "prime time" which is when I do the bulk of my listening. I understand the concept of the EF-SWL but I have not been able to find a configuration that eliminates noise at MW and lower frequency HF. As a matter of fact I can't receive much of anything in the AM broadcast band. I understand the EF-SWL is not ideal due to its length.
So, after doing some reading here I've begun to think about a loop. I am leaning towards the Pixel RF Pro-1B simply because it's American made and if God forbid it arrives "DOA" I'd at least be able to easily exchange it. From what I gather from recent comments it seems that this loop may be equal to the latest Wellbrook ALA-1530S+.
My question is this. Given the small footprint of my lot combined with the close location of my neighbors, do you think I gain anything by mounting the antenna away from my house. No matter where I go with it it's going to wind up being closer to one of my neighbors. Ideally I'd like to mount it on the roof of my house. I currently have a 3' tripod available, and I have a Channel Master rotor waiting to go. I'm curious as to thoughts from the experienced users.
Another consideration is to try a different configuration of the EF-SWL, which would be the cheapest option obviously, but this thread is to primarily ask about loop location and the "experts" thoughts on it.
Thanks in advance!
Thanks in advance!
