Antenna tuners is a little misleading so I'll just call it an antenna matcher because I think that's what it really is isn't it? Using a long wire on an ICOM R7100 receiver, which antenna matcher would anyone recommend? I don't need to buy one with a meter because there will not be any TXing going on. With the wide band coverage of the R7100 wouldn't an antenna matcher just need a band selector and a tune knob? You just monitor the signal meter on the receiver while tuning correct?
A tuner probably won't help much, if at all. Yes, you will hear more signal if you tune - BUT you will also hear more noise. And what counts is how strong the signal is compared to the noise. A tuner won't change that.
Modern receivers are exceedingly sensitive and a wire about 15 feet long is all you need with one. What matters more is how high it is off the ground (the higher the better) and how far it is from sources of radio frequency noise (and your house is a major source of that).
Transmitting changes things because you need a good impedance match to avoid wasting power or, even worse, getting strong RF signals in the shack. So unless your antenna is resonant on the transmission frequency you need to tune it to match impedance.
But with a receiver, so long as you can hear the signal that's the best you are going to do. Adding a preamp or an antenna match will amplify the noise as much as the signal. If the signal is noisy already and you can't move the antenna, make sure you have a very good ground or a radial system or counterpoise.
I have 30 feet of wire about fifteen feet off the ground. Connecting the ground terminal to a counterpoise made of 40 feet of co-ax shield drops my noise figures considerably.
