- Joined
- Jul 6, 2013
- Messages
- 49
I received this ARAV3-1P antenna yesterday. Here's a few quick comments about this antenna. It arrived UPS very well packed. The whip is a one piece tapered 108" rod which they pack in a stout cardboard tube.
When I bought this, I thought $259 was a bit on the high priced side. When I received it, I was amazed that it could be done for this price. It is a marvel of good and proper engineering and manufacturing. I've gotten so used to cheap imported goods with crappy hardware and ludicrous instructions that I had forgotten what a well engineered product felt like. All the pieces are made with beautiful precision and quality materials. High grade aluminum enclosures, and all stainless steel hardware. Remarkable. There is also an 8 x 10 instruction booklet that is both comprehensive and clearly written in REAL ENGLISH!
I assembled the pieces easily in about 15 minutes. I had to add coax, connectors (more about that later) and a 5' copper pipe to complete the installation. Fortunately the copper pipe pounded into the sandy soil easily for about 2 feet. One small quibble with design. The book says "use 3/4" copper pipe." When I got to Lowes, I see 3/4" copper pipe comes in Type M and Type L. One is clearly thicker walled than the other. I choose the thicker walled one because I will be pounding it into the ground. But, the U-bolts were too narrow for the thick walled 3/4" pipe. They were designed for the thin wall. So, with the pole already pounded into the ground, I used a large C-clamp to squeeze 3 spots down so the U-bolts would fit.
The whip and active electronics box mount to a very thick plastic plate which is then U-bolted to the copper pipe. A single coax then leads from this to your indoor station. Indoors is the wall wart power supply, and a small feed box where the antenna and DC power supply connects, and you then connect the radio to this box with a separate coax. This caused some puzzlement to this newbie. The antenna to feed box coax has F-connectors both ends. BUT the feed box then uses an RCA connector as output to the radio. I don't understand the reasoning on that. Finding a RG-6 coax RCA connector was not possible in my Lowes or Radio Shack. I settled for a BNC to RCA adapter and put a BNC on the coax.
My radio has an SMA connector, so the interconnect is hokey. It begins with SMA into an SMA-BNC adapter, The cable is BNC-BNC and connects to an BNC/RCA adapter at the feed box. I wonder why the feed box had an RCA output?
I finally got the thing connected to my WinRadio Excalibur. I really don't know whether to be elated or sad. The antenna raised the overall sig level by about 20+dB (into the range of like -80dB). Such that, listenable signals were hitting S9 to S9+3dB or so. There was still a lot of noise. and I can't say I was impressed by the signal strength. But, this is coming from a newbie who is not sure what the gold standard would be. I know my location is noisy, and my ability to place the antenna in a noise-free area is limited by being on a small mobile plot. So, I know the compromises. I don't know what kind of expectation to have here.
I spent a lot of time playing with the software noise controls, BW and features to make the signal sound better. I shut it down at midnight and wondered like Peggy Lee, "Is that all there is?"
I have a sense that maybe I have missed the "golden age of SWL."
I should emphasize that the DX Engineering antenna was absolutely beautifully made. I would not hesitate for a second to buy other products from them. (No connection of any kind to the company!). If only more things could be made that way.
I have an active loop antenna on order also. It won't be here for a couple weeks though,
