I've tested the Apex, and it is a good design *IF* an antenna only 6 feet long works for you - such as with portables susceptible to overload from larger antennas.
The coax itself is either heavily choked in the whip base, or the shield is disconnected entirely. Hard for me to tell. Part of the problem with diy setups running coax is that the common-mode of the coax becomes part of the antenna, and in an apartment, the coax itself can pick up all sorts of junk, run up to the antenna and back down. The Apex also appears to use either a balun or resistive network to allow for passive broadband matching of such a short whip. What we're really talking about is loss, but for a portable that may not be such a problem.
The cure for this is an RF-choke. You could emulate the Apex somewhat with an MFJ 915 choke, and a 6 foot piece of wire.
Because the coax is not contributing common-mode reception, the small-ish Apex can be moved / tilted in order to achieve the best S/N ratio, and not necessarily the strongest signal. It is built well, and could easily live on a balcony. Just don't assemble the whips over carpet, because if you do and a setscrew falls out during assembly, good luck finding that thing in the carpet. Ask me how I know.
The Apex is good for those needing a beefy short antenna that is only 6 feet long that can survive the elements better than some bell-wire hung off the end of a 1:1 ferrite choke, but it is still only a 6 foot passive-match antenna. Since the coax is choked / isolated, this small of an antenna would be ok for portables, or if you encounter SEVERE overload with a high-end receiver.
Ideally, you'd take your portable out to your intended location, and do a site-survey with your portable receiver's built-in whip first, note the s/n ratio at various angles and mounting positions, and THEN mount the Apex permanently in a similar fashion.
That being said, I found I personally didn't need such a small antenna, despite the overall beefy build. In an apartment where only 6 feet of space is available, (be it horizontal or vertical or any angle you choose - the mount allows for movement), and with an over-sensitive portable, the Apex might be a good choice especially since the coax seems to be isolated.
