Yes but only within the frequency range of its two bands. I've not seen one by MFJ/Comet/Diamond that will separate frequency ranges within the HF band but there are some that will separate HF and 6m where you could have one antenna feeding say a 10m radio and a 6m radio.
If you want to run one antenna feeding a radio on 40m and another on 80 or 20m, etc at the same time, that is possible but with some very exotic band specific filter/diplexers.
prcguy
Universal Radio has the Apex SPL-2 splitter/combiner but it's $120. I was hoping that a duplexer would work. I kind of realized what you said but wanted to make sure. Thanks for the reply.
I was assuming transmitting was part of your plan. If this is for receive only then all you need is a 2-way power divider rated for the frequency range you need. You can sometimes find them on Ebay for under $20. Just be aware a 2-way divider will loose at least 50% or 3dB of the signal fed to each receiver but that's usually not a problem for the low to mid HF band. You will notice the loss at the higher end of HF where atmospheric noise does not dominate your receiver noise floor.
prcguy
I made one some time ago - don't use it now as I have an amplified multi-coupler, just simply soldered across the backs of three BNC sockets, don't know why the resistor is 18ohms....
