So I live in a basement apt. thats 1/2 way under ground. Makes the grounding part very easy. So this is what I created:
GROUND
A 24" copper pipe that has stripped wire spooled around the top then wrapped in electrical tape. From this a 18ga wire comes in through my window where it goes into a short 6" piece of rg6? cable left by the comcast people. Its connected to the shielding.
ANT
The center copper wire of the cable is connected to a roughly 30' length of stranded 18 ga wire that runs horizontally along the ceiling.
So here is what I heard the 5000kHz Canada tine signal comes in very good at night. All signals seem louder and on some bands the noise is ALSO louder. But on 5MHz and 27MHz (quarter and full wave length for this size ant. I think?) The noise is lower. At 27MHz something weird happens almost no static or 60MHz harmonics but a strange almost 10or 20 Hz buzz sound comes out: This happens on other bands too but not as bad. Picked up some distant CB signals but here in Baltimore MD not many use a CB. Almost none of the hiss static at 27MHz.
Is this a feature (the buzz) of running a full wave length? Seems this antenna really needs the ground to work; the wire by itself seems to only work a little better then no antenna. Why? Is it over loading this radio? Just a few really hard and vague no simple answer questions I have.
GROUND
ANT
