ka3jjz
Wiki Admin Emeritus
While cleaning up the loops wiki, I found a few more loops that folks might be interested in
The first one isn't a good choice if you tune below 6 Mhz or so....while the other 2 do. In fact these non-amplified loops might be ideal for those using portables or SDRs without a lot of front end filtering like the RTL-SDR (depending on the upconverter, of couurse, since these don't natively tune too far in the HF band...)
https://www.dxengineering.com/parts...leon-antenna&gclid=CPqzz--gnNECFYaPswodwQkCoA
10-80 meter magnetic Alpha Loop antenna +6:1 drive [10-80MeterAlphaLoop+BoosterCable] - $325.00 : Alpha Antenna, Civilianized and Militarized HF antenna systems for Portable, Base, Mobile, Manpack
Review of the DoxyTronics 8020CA magnetic loop antenna | The SWLing Post
