Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Receive Antennas (below 30MHz)
Receive Antennas (below 30MHz) - For all topics related to receive antennas used on HF, MW, LW, etc. For transmit antennas use the Amateur Radio Antennas forum.
Old 05-01-2017, 4:09 PM
majoco's Avatar
Default MFJ - 1886 loop
Hi Guys - I've been toying with the idea of making a loop instead of buying one at about NZ$800 plus! However I see that the MFJ-1886 is more in my price range - any got one to give me some idea of it's performance? I was dissappointed with a Wellbrook that I borrowed - I have quite high noise levels in the evening from neighbours TV which I would hope to eliminate - I would mount it on a mast about 15feet up on a cheapo rotator that has been unused for years!
Any help gratefully received.
Old 05-01-2017, 5:18 PM
Post
Originally Posted by majoco View Post
I was dissappointed with a Wellbrook that I borrowed - I have quite high noise levels in the evening from neighbours TV which I would hope to eliminate...
This is not the fault of the antenna. This is your location. No antenna is going to magically rid itself of RFI.
You're better off buying one of these OR removing the offending source of noise.
Timewave ANC-4, Timewave ANC4 noise canceller
MFJ makes one too but just remember the MFJ motto == Mighty Fine Junk!
