I'm a shortwave listener - interested mostly in hams and broadcasters below 30MHz. My receiver is an RSP2Pro (software-defined receiver). I have erected a U-shaped, end-fed longwire antenna - total length about 75 feet, all segments of the U are approximately equal in length. (I chose this configuration because of the space I have to work with). It is about 30 feet above the ground. The antenna feeds into a "matchbox" with a 9:1 transformer. The matchbox outputs through about 10 feet of coax to the high-impedence port of the receiver.
I occasionally listen to VHF/UHF on the RSP2Pro using a simple, car-top scanner antenna. Today, as an experiment while listening to HF, I switched over from the longwire to the VHF/UHF antenna. To my surprise and disappointment, there was virtually no difference in signal strength or quality vs. the longwire. How could this be? What is wrong with my longwire antenna? What can I do to improve it?
Thanks!
Thanks!
