ka3jjz
Wiki Admin Emeritus
There's an article on the SWLing.com website reviewing the Bonito e-field antenna, the MA305
Brilliant hard-core DX with the USB-powered Bonito MegActive MA305 antenna | The SWLing Post
and as for the antenna itself...
https://hamradioshop.net/en/Antennas/MegActiv-MA305-Active-Antenna.html
Being an e-field antenna, you need to be in a real quiet area, able to put the antenna a good distance from the home (like a rural setting) to use this antenna effectively. Otherwise you may hear a lot more noise than signal.
