Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Receive Antennas (below 30MHz)
Receive Antennas (below 30MHz) - For all topics related to receive antennas used on HF, MW, LW, etc. For transmit antennas use the Amateur Radio Antennas forum.
Old 10-29-2017, 7:50 PM
Default RA0SMS Active Mini Whip
Hi all,
Just wondering if anyone here has or has used RA0SMS' mini whip antenna.
I will be using it with an RTL-SDR for HF utility and broadcast listening.
Also the eBay page says that BNC connectors are included and all you need is coax. Is that true?
Regards,
Sam
Old 10-30-2017, 1:56 PM
Wiki Admin Emeritus
A RTL-SDR only goes down to 25 Mhz, if memory serves. Are you using some sort of upconverter for HF coverage?
While this article is addressing using that antenna on a SDRPlay, not a RTL stick, the observations are worth noting. Not a particularly good performer, it seems - way too sensitive to E field noise (as are most all mini whips) and overloading issues. There seems to be some instability issues, too...
RA0SMS Miniwhip bad performance on SDRPlay - SDRplay Community Forum
What is your situation? It sounds like you're in a flat or other space where you can't put up antennas...as are lots of us (unfortunately)...Mike
co-author, HF Digital Decoding
Old 10-31-2017, 6:38 AM
I currently live in a suburban area and I am planning on riding my bike out to the local scout camp for a day and setting up. My dad runs a Wellbrook magloop and it is still an S4-6 noise floor.
The rtl-sdr.com V3 has HF when you use Q-branch in SDR#
