As I wrote to the OP, you need nothing more than a single high point to mount it, then spread the legs out in a roughly 45 degree angle, and don't let the legs touch the ground. For receiving that will work just fine. A pretty simple antenna to work with - now all you need is a proper feedline (depends on what is being used at the feedpoint) and you're good to go...Mike
