srrcs is rebanding in 2011
ssd
NEVADA
OK i know the srrcs is going to reband some time in 2011 i got this form 2 department heads in sac all radios need to be in the radio office by years end for rebinding programming. so soon we all will need new scanner if u don't got a good 1 by now. maybe some1 else will p25. yea
sacscan
Sacramento, CA
While programming a scanner for an SSD deputy last night, I commented on the terrible Site 002 reception on his scanner (it's a Pro-94, so anyone who's used one probably knows how interference-prone they are). He told me that they are rebanding soon. I asked him how soon and he said in the next 4 to 5 months.
Markinsac
Sacramento, CA
According to information I've heard, the process starts in October.
My guess is that the radios will be flash-upgraded (or replaced if too old). Newer radios should allow OTA reprogramming.
I haven't seen a license for a trunked system yet - only for a conventional system. Will they run the two systems in parallel for a while?
Also, I hear that they will still be done by May 2011.
WayneH
Forums Veteran
Super Moderator
Your master site
You can't OTA reprogram with a 3600 trunked system. Also, they're just rebanding so there will not be a new system built alongside the old one. The existing infrastructure will get reprogrammed. Since the system is new enough the transition should be as simple as flipping a switch (ok, a little more effort) once the subscribers have been reprogrammed.
avtarsingh
Cyberspace
if its typical like how the state does rebanding
the new rebanded control freqs will be streaming new and old -back to back repeaters
and after all radios are programmed with new control freqs
the old control channels are turned off
like how wayne was saying
thats the usual easy way to switch over without causing interruption of service
the smartzone switch was to allow the zones they have and it allowed the p25 and encryption capability
Sac916
Starts Oct 1st through spring 2011
Markinsac
Sacramento, CA
Any information on the proposed frequencies? Control channels? As I've mentioned before, the only license applications I've found so far are frequencies for conventional, not trunked
WayneH
Forums Veteran
Super Moderator
Your master site
There should be (or will be) licenses with the new rebanded frequencies. They'll have a different service type (as opposed to YP, etc).
avtarsingh
Cyberspace
there was a freq list floating around somewhere that had the rebanded freqs listed
i have some of them i pasted from my scanner load -
sac county
851.13750
851.26250
851.41250
851.43750
851.46250
851.60000
851.65000
851.77500
851.80000
851.85000
851.88750
852.03750
852.07500
852.15000
852.17500
852.25000
852.32500
852.35000
852.40000
852.68750
852.80000
852.87500
853.18750
853.26250
853.32500
853.36250
853.42500
853.45000
853.56250
853.68750
853.80000
853.85000
853.87500
sac city
851.05000
851.11250
851.32500
851.38750
851.62500
851.67500
851.75000
851.82500
852.10000
852.30000
852.46250
852.57500
852.63750
852.71250
852.73750
852.90000
852.96250
853.10000
853.16250
853.61250
853.71250
853.77500
853.90000
853.96250
uc system - uc davis
851.075
851.225
851.2875
851.4875
851.9875
852.4875
852.9875
853.4875
CMARS and state freqs
851.0125
851.2
851.5125
851.5375
851.9125
852.0125
852.5125
852.5375
853.0125
853.3875
853.5125
853.9875
city of davis
851.6625
852.275
852.6625
853.075
853.6375
ssd
NEVADA
What will be the new control channels for the new rebanded systems
Markinsac
Sacramento, CA
Some of the Sacramento County frequencies shown above are included in their conventional system application (WPHZ928) - license class GE. Some aren't on that application. I still see no application for frequencies for a trunked system.
ssd
NEVADA
A friend in ssd parking enf said he got a department momo ssd is going full p25 with the reband. I hope so. It will improve the radio range and system rx
avtarsingh
Cyberspace
typically the control channels SHOULD be (but dont have to be ) the highest 4 freqs in the channel list
i ASSUME the reband will go thru first - then if everything is successful p25 would kick in for the applicable channels
mkewman
Sacramento County, California
based on that list i would assume that the city frequencies would be Site 1, County would be Site 2, I'm going to create a couple of systems with those freqs and see if/when they start popping up.
crucialcolin
If that's true I'll have to go to a BCD396XT. Not sure if I'm ready to drop $500+ on one yet. I've been trying to wait for the price to go down on these digital scanners. I guess that's the cost of progress though.
ssd
NEVADA
Will everyone in the valley has been lucky no major police or sheriff has gone p25 fully pcso well soon. But a lot of pds and so have stayed with what they have
I hope for more p25 non encryption.. dos any 1 see any new cc poping up. Now talk. Groups?. And can we make this the sac county reband where we have all the post go here I see we got 3 let's keep it here. Thanks administrator
