SURCOM Programming Help
dsefcik
Hi, I hope someone here can help me. I am trying to get Surcom (857.125) programmed into a Wouxon KG-UV9D Radio. I can successfully listen to Surcom on my Uniden 436HP but using the same parameters on the Wouxun doesn't pick up any transmissions.
From the RR DB, this is the programming for it:
857.12500 KNJJ566 RM 115 DPL DPR BLACK MTN Black Mtn - Picacho SRA FMN Law Dispatch
Attached is screenshot of what I have tried in my radio so far.
I am thinking there is some kind of digital signal happening or something else the Wouxun doesn't support, hopefully somebody here is knowledgeable enough to help me fix it or point out why it won't work.
TIA
kma371
QRT
TIA
Might be a tone issue? Try listening without tones.
dsefcik
Try changing from fm narrow to fm
I believe I have tried both of these options already but will test again. Both the RR DB and Uniden list the frequency as NFM and the tone as DPL/DCS 115. The RR DB does not indicate the polarity but I have tried (shown in my previous screenshot) both DCS Polarity N & R.
I can test the "D Code" only option in the radio which RT Systems define as
"D Code: A DCS (or DPL) code is applied to outgoing transmissions. No squelch mode is applied. This may also be known as “Encode Only”
Thanks for the suggestions!
K6CDO
Hanover Co. VA
You might also check the 'rebanded' channel 856.4875, as I believe the State may be in the process of retuning their assignments.
(If you are still hearing 857.125 at Black Mountain on your 436, then disregard.)
dsefcik
Thanks...yeah, 856.4875 is silent on the 436. I will test some of the other suggestions tomorrow when I am out in ABDSP.
