In the User Manual it states the weather frequencies will not work in the UK. D'oh! I guess the scanner came from there and that explains my problem. Moan!
~Falcon
I think you may be misinterpreting what the manual says.
"It says the weather chls will NOT work in the UK",
NOT "the weather chls will Not work in the US"
This is because the scanner is made to operate in the US and the PRE-programmed weather chls are NOT the same as the weather chls in the UK. (if they even have chls).
You may be just getting front end overload. I just visited my brothyer in SJ at Xmas time and showed off my GRE 600 (he still uses the older bc780s) and the weather service worked fine, think I got 3 or 4 chls.
BUT, I did use my FM broadcast band (88-108) filter which reduces front end overload by a ton.
He always complains about VHF overload and intermod so I put my filter on his scanner and it worked great.
May or may not work for you, just a thought.
Dave
